To Connect the throttle cable to the quadrant, there was a bit of engineering required as the cable needed to be floating mounted in terms to follow the up and down movement through the quadrant leverage. This was achieved with a clamp setup for the cable head, to lock the cable in place but allow to move 2 deg up and down so that the shaft of the throttle cable was not binding.
