Michaels Web Site
Date:  5-18-2019
Number of Hours:  4.00
Manual Reference:  40
Brief Description:  Preperation for Toe Setting
Time has come to set the Toe on the main gear. First I had to remove the break calibre so that I could attached two straight edges to the brake discs as per earlier manual.
Having the air plane level and a laser level through the centre, measuring the wheel alignment with zero Toe with max weight in the cockpit, used a few bags of cement to simulate wings and pilot!
To align the wheels a lot of measuring and twisting of the leg was required.
To my surprise the weight had not changed the toe setting!
Laser line through the centre
Straight edge on brake disc
