Garys RV-7 Builders Log
Date:  4-11-2013
Number of Hours:  1.50
Manual Reference:  8-10
Brief Description:  Forward fuse misc work
Tonight, I cleaned and primed the overlapping area of the forward and center bottom skins. I then drilled to #12 the steel lower engine mount bolt holes. I also installed the AN3 bolts, washers and nuts. I still need to torque and mark these fasteners.
