Garys RV-7 Builders Log
Date:  3-3-2013
Number of Hours:  4.00
Manual Reference:  8-10
Brief Description:  Priming fuse parts.
Today, I first cleaned the forward bottom skin and the longerons. I then primed them with 7220. I also masked off the aft fuse section, cleaned and primed the forward rivet holes that connect it with the forward fuse and overlapping forward skin.
Lastly, I removed blue plastic from the rivet lines on the side forward side skins. I then started deburring the left side skin before going to bed. Diane hung out in the shop and watched The Housewives of Atlanta while I deburred.
Primed bottom forward skin
Primed aft fuse forward rivet hole area.
Removing blue plastic from rivet lines.
