Brief Description: F-796B angles, Gerry stopped by
Today I fit and match drilled the F-796B angles and the F-796 spacers on both sides of the fuselage.
My A & P (airframe and powerplant mechanic) neighbor Gerry stopped by to look at my edge distance concerns for the outer most firewall angle and F-684 gussets. He said it was fine and of no concern. I could add additional rivets closer to the angle web between the holes, but not necessary. I plan to leave it as-is and build on.
To finish up the day I pulled out all the rudder pedal and brake components. I deburred the four F-6117A brake side plates and called it a night.
