Garys RV-7 Builders Log
Date:  9-8-2012
Manual Reference:  8-6
Brief Description:  Installed F-770 forward fuselage skins.
Today I made shims and adjusted the saw horses height using a string to get all three of them level. The F-705 bulkhead was sagging a little so I used a bar stool and blocks to hold it up. The forward skins were then able to be clecoed in place. It still took a little jostling around, but raising the sagging F-705 was key to making everything line up. Finally.
My next task was to locate the F-720 armrests. This took a little time rummaging through the parts, but once found, I deburred them so they are ready to cleco in place next time.
New saw horses, leveled.
Side skins clecoed, finally.
Inside view of the
Inside view of the "canoe"
