Brief Description: Center fuse seat ribs continued.....
Today, I first cut the F-716 ribs and removed a portion of each for control access. I then deburred the access plates, the removed portions, and the ribs. I cleaned them with MEK and primed with Napa 7220. These small parts are tedious and time consuming.
Tonight I drilled, deburred and riveted the seat rib access plates to the portion of the ribs that I cut out this morning. I then match drilled the holese for the 8R8 screws to size #19.
Colten also helped me with the last few aft fuse bottom skin rivets.
