Garys RV-7 Builders Log
Date:  2-12-2012
Number of Hours:  4.00
Manual Reference:  8-5
Brief Description:  Start work of tail wheel mount and spring
I visited my neighbor Gerry who has built several airplanes and he was nice enough to loan me 125 3/32" clecos.
Colten finished clecoing the bottom and side skins to the aft fuselage bulkheads. I worked on drilling and fitting the WD-409 tail spring mount to F-711 and F-712 bulkheads. I also used the plans template to trim the F-779 tail cone skin. I match drilled to size D the holes for two 1/4" bolts through F-711. I still have some work on this assembly, but it is getting close.
Colten saving my back and knees.....
Tail cone skin and wheel spring mount
Tail cone and wheel mount assembly
