Garys RV-7 Builders Log
Date: 2-4-2012
Number of Hours: 4.00
Manual Reference: 8-4
Brief Description: Finished bulkhead, started longerons
Today I started by fabbing the F-710B angle, cut to length, tappered ends, match drilled, deburred, cleaned, primed and riveted it to F-710 bulkhead. Bulkheads are done for now!
Next, I cut the longeron angles to length, marked bend points and made the bends with Coltens help. It wasn't a big deal, just took some time. I had a little twist in each that was easy to take out on the vise. Next, I need to make the bend on the forward end of each longeron and put in the required twist.
Bending right longeron in vise.
Checking angle bend with template.
Both longerons with first bend complete.
