Garys RV-7 Builders Log
Date:  11-21-2011
Number of Hours:  1.00
Manual Reference:  8-1
Brief Description:  Fabbed F-601TD Brake Line Bracket
Started back to work on the F-601TD and accidently overdrilled one of the holes with the unibit to 1/2" and it should have been 7/16" so I had to make another one. It turned out good and then it was match drilled to the firewall.
I also realized today that the F-601J angles need to be off the bottom support angle 3/32" as shown in small print on the drawing. I may be able to remove a little material and still have acceptable edge distance to the holes. I'll check this next session.
F-601TD match drilled and positioned
3/32" bit shows amount of material to remove
back view of firewall....
