Garys RV-7 Builders Log
Date:  1-21-2008
Number of Hours:  1.00
Manual Reference:  6-13.9
Brief Description:  Installed rod end bearings in to horizontal stabil
No pics of putting the bearings in. Not much to it, simply thread the stud into the nut plate until the bearing hole center is 7/8" from the surface of the horizontal stabilizer spar. They will probably need some adjustment once the elevators are installed to give the proper clearence and to make sure everything is aligned.
