Garys RV-7 Builders Log
Date:  10-26-2007
Number of Hours:  1.25
Manual Reference:  6-7.6
Brief Description:  Started on the rudder trailing edge preperation.
Today I started on the rudder trailing edge. First thing was to match drill holes for the skins and AEX wedge that goes in between them. I am not sure what AEX stands for, should probably find out. All it does is give support and shape to the end of the rudder where the two skins narrow to a point. Next I counter sunk the wedge to it would fit well with the dimpled skins.
When clecoed it had a pretty good fit, could have been a little tighter, but it really just cosmetic. I will put a little filler in to fill the gap before painting.
Clecoed rudder to angle and bench.
Gap between skins and wedge.
After clamping, it fits pretty well.
