Garys RV-7 Builders Log
Date:  8-15-2007
Number of Hours:  1.50
Manual Reference:  6-3.17
Brief Description:  Drilled out rivet and primed rear spar.
Tonight I drilled out the bad rivet with a "Smiley" that Donnie pointed out to me a few weeks ago. This process involves drilling out the manufactured head and using a punch to break it off. The rivet is then tapped out with a punch from the shop head end. I didn't enlarge the hole, so I was able to use the same size rivet for the replacement. Turned out good. After that I touched up the primer on the rear spar and took some pictures of the other finished parts.
Rear spar on
Rear spar on "paint cart"
Primed HS skin.
Primed HS skin.
Primed ribs, etc.
Primed ribs, etc.
