Matt's RV-8 Project
Matt Dralle's RV-8 Project
Date:  5-8-2015
Number of Hours:  1.00
Brief Description:  New Engine Cowling Finish Work - Part 1
The new cowling for the RV-8 is turning out amazing. Here are some pictures from Friday. Most of the surface pinholes are filled now (gray filler) and most of the gaps are set between the top/bottom and back/fuselage. Oil door fit and finish is amazing. The cowling is going to look pretty sweet.
Gelcoat next, then sanding, then primer... So close!
