Matt's RV-8 Project
Matt Dralle's RV-8 Project
Date:  2-21-2009
Brief Description:  Rear Stick Installation & Wiring - Part 2
You can see from the two sets of travel sequences that the cable layout came out perfect. The cable basically rolls and unrolls with the left/right movement of the stick.
With full down stick, the grip clears the back of the pilot's seat by about 1/4". Full left/right and back stick is also easily attainable without too much fidgeting around.
The front stick will be a little trickier because the bottom of the instrument panel is a little sketchy right now since I'm using the Plexiglass panel still and the bottom bend isn't there. But, I have to install the front grip to finish up the wiring.
Bulkhead Mount DB25
Bulkhead Mount DB25
Jack Screws For Mounting Grip Side Conenctor
Connector Installed
Connector Installed
Copyright © 2008-2024 Matt Dralle. All Rights Reserved.
