Matt's RV-8 Project
Matt Dralle's RV-8 Project
Date:  7-14-2013
Number of Hours:  1.00
Brief Description:  Matt's KLVK ATC Streaming - Part - 02
So next, I made an audio connection from the handheld to the Line In input on the computer. Sure enough, now I was getting great sound from the hand held on the computer! I found some software from Australia called BroadWave from a company called NCH (http://www.nch.com.au/streaming). It lets you connect to the Line In port on the computer and then generate real time audio streams that can be served up via the Internet. And sure enough, it works great!
Next, I found some software from Germany called Loop Recorder (http://looprecorder.de) that let's you monitor a audio input on your computer and generate archive files. You can select an increment in which to rotate the files automatically, for example, every 30 minutes. I downloaded this software and installed it and sure enough, I was able to start archiving the ATC transmissions coming in, all the while streaming them live as well!
Cont Next Log...
