Brief Description: Throttle quadrant and cable holder
Finished adjusting the quadrant to take the connector for the throttle cable. Lots of assembly, stripping and reassembly...
Had to work out a way to hold the outer cable on the throttle cable - after two tries with alloy and SS - ened up using a nylon block (laminated cutting board!). Refitted the console and the cable clears all obstructions.
Motivated by seeing a finished Lightning land in Perth (in from the East). Great sight to see.....
