Brief Description: General work on canopy frame and elevator trim tab
Removed the canopy frame once again to do a bit more filling on the inside surface. This surface can be seen clearly when flying so I really want it to look good.
Continued work on the elevator trim tab. Gaps have been reduced and alignment trued. Had good fun making the dinky little control horn for the trim tab!
