Patto Web Site
Lightning
Glassing HS to VS fairing
Bolted the HS to the fuse and glassed top joint. Rolled the aircraft and glassed the bottom joint. Started filling and flushing the bottom fuse joint seam.
Glassing top joint HS to fuse
Glassing bottom joint (after rolling aircraft
Filling bottom joint while aircraft is flipped
Lightning Home
1385
319
449
