More sanding and filling on the underside - now just need to sand all the gellcoat on the underside to finish.
Moved on to preparing to fit the main gear - now the wheels are fully assembled. Sanded the front gear leg tube till the front leg fitted well.
Started re-assembling the main gear brake assemblies but noticed that the caliper retaining bolts need to be lockwired - so now need to buy lockwire & lockwire pliers ...................
Removing paint so front gear leg fits in mounting tube.
