Patto Web Site
Date:  7-14-2009
Number of Hours:  1.00
Brief Description:  Removing toe brake bars from right side.
Finished removing the full rudder assembly. We have brakes only for the left seat - se we decised to remove the brake bars on the right side.
Our logic is that if brake bars are fitted - they should work. As we are not fitting brakes on the right side, it would be misleading to leave the brake bars in place. Carefully cut the last 1/8"" of the rudder bars - then twisted off the rest of the stopper - then slid the brake bars off. Filed the ends smooth. Will paint the exposed bars later to control corrosion. Will keep the brake bars - we can always put them back on should we decide to fit right side brakes later.....
Cutting off RHS toe brake pedals
Pedals removed
Pedals removed
Grandson Cody sharing the living room with wings .....
