Patto Web Site
Date:  1-27-2012
Number of Hours:  5.00
Brief Description:  More work on panel.
Getting the panel ready for "face" plastic sheet. The plane is to use the alloy sheet to give strength with a coloured plastic sheet glued to the front to look good. Trimmed 2mm all around so the alloy sheet will be sammler than the face sheet. Then located and cut the holes for the main instruments. Deburred, filed and sanded all edges to avoid blood behind the panel in the future.
Fiddly but enjoyable work .............
Trimming panel edges.
Cutting radio & transponder holes.
Ready for feature face sheet.
