Continued work on the rudder assemblies. Made up the brackets to fix the cables to the rudder. Fitted the brackets to the rudder - then refitted the rudder. Made the rubber cushions for the brackets (cut from fuel line).
Pulled string lines through the rudder cable path to work out which access holes needed adjustment (ie enlarging). Had fun widening the the holes in the bulkhead at the back of the fuse - not much room back there ... Had to adjust all holes - including the newly cut access holes through the seat bulkhead.
Shortened the turnbuckles (as per manual instructions) or Rodney did with his band of interested apprentices ..."
