Brief Description: Finished rudder pulleys - cutting out for rudder c
Rithy visited from Cambodia (Transfrom Cambodia) and was greatly interested in the aircraft.
Finished the rudder pulley assemblies - including assembling the pulleys, feeding the cables and riveting the pedal assembly tube into position. Pulled the pulley assemblies apart and fitted them with hose spacers to hold the side guides away from the pulleys.
Refitted the rudder cable guides under the spar box. Started out with the 6 washers as spacers as per the manual - but the guides were pushing against the floor. Took out 5 of the washers which lifted the guides just clear of the floor.
Measured to locate the centreline on the floor - then marked up for the rudder cables holes and the elevator bell crank hole. Cut the holes and smoothed them."
Rithy (from Cambodia) inspecting the plane
Locating the centre - and the rudder cable holes through the seat back
Cutting rudder cable holes and elevator bell-crank hole through seat back
