Patto Web Site
Date:  3-29-2009
Number of Hours:  2.50
Brief Description:  Removal & refit of canopy with panel and edge seal
Before the final fit of the canopy (ie the final trim of the bottom edge to give the shut-line for the canopy) have to re-install the panel, the sealing rubber, the struts and the top latch. With these all in place, the canopy will sit where it will end up sitting in the completed aircraft. The gap can then be sized properly.
So once again, the canopy comes off - panel and seal go back on - and the canopy goes back on!
Starting to look good now.
Rubber seal back on again.
Panel back in again - followed by the gas struts.
