Patto Web Site
Lightning
Firewall & rudder work
Finished smoothing the rough cut firewall - draw filing and sanding. Long, slow process but it provided a break from thinking!
Started finishing the rudder. The joint between the halves needed filing and then filling. Good side job to work on between the critical path work.
Firewall trimmed and fitted
Rudder joints filed smooth
Rudder joint filled
Lightning Home
1385
319
449
