Brief Description: Removing the master relay - general elec work
Tested the master relay (with Ed) and determined it was faulty. Had to do the squirm under the panel to get at the retaining bolts to release it. Test fitted all the AOA bolts - had to dremil out clearance holes through the seat side supports to get at the rear bolts. Lots of fiddling and wing twisting to get the bolts started.
