Patto Web Site
Date:  2-8-2012
Number of Hours:  1.00
Brief Description:  Recutting the thread on the fuel pressure sender.
More fun and games. After visiting 4 fittings shops, was advised there would be no fittings bin Austtarlia to match unless someone had a spare odd-ball .....
Had to buy the fitting then recut the thread on the pressure sensor with a 1/8 NPT 27 die. Took a lot of slow work but now I can connect the 1/4" fuel line to the pressure sender. Would have been much easier if the fitting had been supplied by Dynon ............ pretty obvious it had to be connected to a 1/4" fuel line.
Now to source the extra fire sleeve needed.
Cutting away ......
Cutting away ......
Fuel line barb fitted.
