Spent two evenings doing the final finish of the panels. Removed and refitted the removable centre base frame to check it worked. Made some small uprights at the back of the rear bottom frame to stop the bottom of the rear panel from bowing backwards when pushed. Won't do any more until upholstery design and finish is decided.
