Brief Description: Lots of general work - oil cooler, glare shield &
Finished the oil cooler duct - changed the design to get a better seal against the cowl.
Fitted the new oil cooler duct and cowl - then cut the air intake hole for the cooling duct. Removed the cowl and tidied the hole. Did final sanding work on all the other air intake holes in the lower cowl.
Carved and sanded the foam filler on the underside of the glare shield. Will leave now until who ever is doing the upholstery advises what prep is required.
Made up yet another centre and fuel console mock-up. This one will do until Mark P does some work interior design work.
Trimming the cowl vent hole for the oil cooling duct.
