Removed the nose gear pant and started fitting the leg fairing. I'd say I'm about half-way through the fitting - then the piano hinge is to be fitted and the lower mount bolt holes drilled.
Starting the trim of the cowl to take the fairing.
The first cut!
The top fit after about an hour's trim, re-fit cycle.
