Patto Web Site
Date:  6-20-2010
Number of Hours:  7.00
Brief Description:  Canopy and general work
More finishing work on the canopy - mainly filling and sanding both the inside and outside of the frame and cover. Very slow work as you are working so close to the canopy - and you need to avaoid scratching it!.
Started on the NACA duct for the oil cooler - and did more fill on the top fuselage joint.
We were also able to do the first test sit to check the canopy clearance - Mark, Andrea, Sheryl & Robert are all fine. I just fit.
Filling the inside gap between the canopy and frame.
Sanding the outside cover.
Test sitting!
Test sitting!
