Primed and painted trim tab skin. The trim tab skin has tabs on each end that are bent using a jig made from ¾” board. If I wait until the tabs are bent, it would be impossible to prime some areas.
Also cleaned and primed the Elevator Trim Horns, and Trim Tab Spar.
