There are so many different stiffeners that it’s hard to keep them straight. So as I trim each one, I’ve been installing it on the appropriate surface.
I received the parts from Van’s this morning, so I will not loose a beat.
Van’s suggests that each part should be marked with an engraver to insure each piece is installed in the correct place after priming/sealing. I am doing this prior to fitting the pieces together.
