Brief Description: Finishing the Vertical Stabilizer
Completed riveting VS skin. Did not notice that I should have omitted 6 rivets on either side of the VS. Drilled out the rivets and began to install K1000-08 anchor nuts. Installed three of the 6 anchor nuts on the RH side of the rudder.
Once again, a note in the instructions might have helped. There is so much information on the plans, that it is easy to overlook critical steps in assembly.
Changed my mind and decided to install K1000-6 anchor nuts instead. Ordered parts from Aircraft Spruce.
