MARTIN'S WEB SITE
RV-12 iS
Corrosion Control
Prepare Rudder Skeleton with EkoEtch
Prepare Rudder Skeleton with EkoEtch.
Painted surfaces with SS Smoke Gray Primer/Sealer. Will rivet the structure after plenty of time for Primer/Sealer to dry.
Began to prepare elevator stiffeners. Cut to length and layout material for removal.
Will work very carefully because of different lengths of stiffeners due to trim tab on the LH Elevator.
RV-12 Home
RV-12 iS Home
1354
728
Flight Controls
Fuel Tanks
Static Discharge Sys
523
