MARTIN'S WEB SITE
RV-12 iS
Wings Leading Edge
Fitting the Leading Edges
Removed vinyl protection from inside L & R Leading edge skins. Also removed vinyl from strips along the rivet holes for outside of skin.
Ran a line with the soldering iron along the inside of the nose of the leading edge skin. Made removing the vinyl much easier.
If you pull up at a 90 degree angle from the skin, the vinyl tears cleanly along the lines prepared with a soldering iron.
The Met radio season was over last week. I missed the broadcast today.
Removing Vinyl Protection
Leading Edge Skin in Jig
Bottom of L Leading Edge
RV-12 Home
RV-12 iS Home
1354
728
Flight Controls
Fuel Tanks
Static Discharge Sys
523
