Brief Description: Tools - Finalizing the Fuselage assembly jig
Late this afternoon after working on job hunting, I went to the shop with the objective to finalize the fuselage final assembly jig. I finished installing angles to hold all the crossmembers up. Then, I wanted to localize all the cross member at their final position. I decided I would not do that, instead, I will build the airplane, then localize proper support where it is needed
