Martin's Aircraft Factory RV-8
Date:  6-12-2017
Number of Hours:  1.00
Brief Description:  Fuselage - External Power Plug hatch door
On this Monday evening, I took the opportunity to complete the External Power Ground Plug hatch door sub assembly. I final riveted the offset hinge previously painted white with Tremclad paint. I then polished the hatch latch a bit with buffer wheel and installed it on the hatch door with pneumatic squeezer. I temporarily installed the hatch door on fuselage side skin F824 LH.
Once that was done, I took the opportunity to spray one coat of grey primer on the NACA duct in preparation for later installation.
