Martin's Aircraft Factory RV-8
Date:  4-30-2017
Number of Hours:  3.00
Brief Description:  Fuselage - fuel Selector Valve support & side cons
On this Sunday, I worked to fit the newly made fuel selector valve support plate on the left side of fwd fuselage. I also fitted the Andair Fuel Selector valve on that plate
Additionally, I drilled holes in LH & RH F844 longerons for the nutplates that will hold the F-811 side console cover plate.
