On this Monday evening, I continued working on the Rudder Pedal assembly.
Per instruction page 8-61, I did:
- Apply a thin coating of Wynns Universal Grease to the interior of the tube on the WD-804-L &-R pedals and on the outside surface of the tube on the WD-816 Rudder Slide. - Re-installed the rudder pedal on the Rudder Slide, and bolted the two F-874 slide block to both end of Rudder Slide - I final drilled #12 the outboard leg of WD-804-l &-R rudder pedal - Final drilled #12 both lugs used for mounting the bottom of the brake master cylinder
