Brief Description: Fuselage - Finalized Center Section
Today, after confirming with Fred if my sligntly ovalized hole for F804G-1 block was an issue, I launched into completing the Center Section sub-assy for good.I first back riveted the Vertical block F804G-1 in place. Then I proceeded with mounting on the F-849 FWD control mount and the F804L-1 seat belt attached lug into place. I did all that before going for dinner. I came back after dinner to rivet both the Front F804A-2 and aft F804B-2 section together. I finalized the Center Section by adding the nutplate required for the optional rear rudder pedal brackets.
I had a few visitors stopping by at the shop. Therefore, I do not exactly how long I worked on this sub-assembly, but for sure I was on it for at least 2,5 hours
