Martin's Aircraft Factory RV-8
Date:  6-11-2017
Number of Hours:  3.00
Brief Description:  Fuselage - External Power doubler and box install
On this Sunday, there was high and gusty winds despite being a beautiful day. We couldn't fly safely, hence this became a day break from flight instructing. I took this opportunuity to make little progress on the RV-8 last few things prior to full fuselage final assembly. I did:
- Final riveted the external ground power plug on the F824 LH skin
- Final riveted the external ground power box to the doubler and F824 skin
- Primed, then painted white the offset hinge for external power hatch door
- Painted gloss black the tail wheel trunnion.
- Finalized the NACA duct "Snake guard", made with PVC rings and aluminum screen.
