Martin's Aircraft Factory RV-8
Date:  6-13-2017
Number of Hours:  0.00
Manual Reference:  DWG 67
Brief Description:  Fuselage - NACA Air duct install with sealant
While taking the opportunity to work from home today, I took 45 minutes at lunch time to install the NACA air duct with sealant on the LH fuselage skin F820. Per the modification I made to the duct, I will install rivets and nutplate at a later time, when the sealant has cured.
