Martin's Aircraft Factory RV-8
Date:  5-2-2017
Number of Hours:  3.00
Manual Reference:  DWG 82
Brief Description:  Fuselage - Fuel Selector Valve Support + fuel line
Still off from work on this Tuesday, I devoted some time in the afternoon to the RV. Main task of the day was to finalize the Fuel Selector Valve Support. I manufactured a round spacer that will fit between the support plate and the console cover, such that the cover will not collapse when the screws are tightened.
Once that was done, I installed fuel line fitting on the firewall. I also made the first fuel line, the vent line for the LH fuel tank. I bended in vent line and pre-fitted it inside the LH MLG tower.
