Martin's Aircraft Factory RV-8
Date:  3-20-2017
Number of Hours:  1.00
Manual Reference:  DWG 81
Brief Description:  Fuselage - Rudder Pedal Assembly
On this Monday evening, I continued working on the Rudder Pedal assembly.
Per instruction page 8-61, I did:
- Apply a thin coating of Wynns Universal Grease to the interior of the tube on the WD-804-L &-R pedals and on the outside surface of the tube on the WD-816 Rudder Slide.
- Re-installed the rudder pedal on the Rudder Slide, and bolted the two F-874 slide block to both end of Rudder Slide
- I final drilled #12 the outboard leg of WD-804-l &-R rudder pedal
- Final drilled #12 both lugs used for mounting the bottom of the brake master cylinder
