Martin's Aircraft Factory RV-8
Date:  3-15-2017
Number of Hours:  1.00
Manual Reference:  DWG 81
Brief Description:  Fuselage - Rudder Pedals
- Started the Rudder Pedal assembly by fitting the sliding tube on the FWD floor in order to match drill the hole from the socket throught the sliding tube
- Fitted the pedal on the sliding shaft, and started drilling the end bocks.
