Martin's Aircraft Factory RV-8
Date:  12-3-2016
Brief Description:  Fuselage - Throttle quadrant fitting on new F864A-
This Saturday evening, my objective was to locate and fit the throttle quadrant on the new and "improved" F864A-1 throttle quadrant support plate made by Benoit Simard. Once the throttle quadrant was fitted and tested for "flushness" with the cover, next task was to make some lightening holes per the original part. I need now to finalize this part by adding holes for cable support bracket, then make an opening for rear seat throttle rod.
Finalizing the newly replicated F864A-1
