Martin's Aircraft Factory RV-8
Date:  6-11-2016
Number of Hours:  1.00
Manual Reference:  DWG 67
Brief Description:  Fuselage - FWD Fuse structure
Tonight, I continued working on the fwd fuselage structure for a short period of time. I did:
- Figure out which screws are AN509-8R12 in my hardware stock. I shall review my stock against hardware specifications to ensure proper screws are in the proper bins. that is the result of Van's sending the screws mix-up in the same bag
- Countersunk screw holes in F822 and F843
- Uncleco and removed the longeron F843-L-1
André came to the shop shortly after I arrived at 8h45. We talked and he had numerous questions about the assembly process for the next steps. Therefore, I estimate I probably worked only 1.0 hours at a slow pace.
