Martin's Aircraft Factory RV-8
Date:  3-31-2016
Manual Reference:  DWG64 & 65
Brief Description:  Fuselage - Seat Rib and Center Section
First started this RV-8 project day by finalizing painting the firewall rotisserie mount. Then I did:
- Removed the F804G vertical blocks on F804B-2 assembly due to the too short AN426AD4-14. Holes will be drilled out dia #21 and AN426AD5-16 rivet fitted instead.
- Seat rib: removed rivet at jct of F806B and F814
- Re-installed rivets at F806B and F814 junction, both LH and RH.
